Old 03-24-2015, 03:22 PM   #1
Engine Speed Sensor....
Hi peeps...
has anyone heard of the Engine Speed Sensor??
I found an old thread on the web and it sounds like it will cure my mystery starting problem as the guy seemed to have the same problem and then put this on the thread.....
From what I can tell, that sensor tells the computer the speed of the crankshaft, which controls spark timing and fuel injection. In my particular case, the sensor was putting out a weak signal, which is really weak in starting conditions (low RPM, low battery). The problem was also heat related -- if the engine was cold, it worked fine. If the engine had been running for a while, it worked fine. If the engine had been running, then shut off and sat for about 20 minutes, it wouldn't work until the engine cooled down further
just can't find a lot about it and wondered how easy it was to fix?
Thanks....
Dext986 is offline   Reply With Quote
