Old 05-18-2015, 07:12 PM   #12
Originally Posted by healthservices View Post
So like in the parking lot speeds when attempting to maintain low speed with the brake pedal it drops right?
brake master...
cups in master are bypassing fluid but if you hit it hard the pedal is stiff...slow and soft, the cups bypass fluid
Nope. Neither of those. Pedal is hard & stay hard.
Seems like the rear is blocked so maybe an ABS issue.
Can you bleed the ABS?
Had a look at it & no nipple so not sure.
I do not have traction control so no duramatic required as far as I can tell from reading the forums.
http://i13.tinypic.com/49ied5h.jpg
2000 2.7 Boxster
aussieboxy is offline   Reply With Quote
