Old drive by cable setup
Hey guys,
Does anyone have the part numbers for the old drive by cable setup? Is it the same pedal as in 996? Also does anyone have pictures of how the cable was routed through the car? I'm working on a Chevy V8 swap and I would really like to convert it to cable throttle to avoid some serious wiring headaches. EDIT: are all throttle pedals identical? It looks like you just change where you route the cable depending on whether you want to go with drive by cable or wire? Thanks, Vlad |
cable
Manual cable peddle #986.423.021.08 Not sure about last 8
Cable # 986.423.221.04 Don't have the picture. |
| All times are GMT -8. The time now is 04:22 PM. |
