Old 03-07-2015, 06:05 PM   #21
There is a good article in the March issue of GTPorsche about the M96 engine.
davedeck is offline   Reply With Quote
Old 03-07-2015, 07:57 PM   #22
78F350's Avatar
Originally Posted by Luv2Box View Post
Does a 2.7L replace a 2.5L without a lot of adjustments or ECU issues?
Here's the engine swap Tech Article on PelicanParts:
Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
The 2.7 will need to be adapted for the throttle cable and the car will need a DME/ECU upgrade.
Old 03-08-2015, 08:02 AM   #23
Luv2Box's Avatar
Thanks, a lot of good info there. I was just looking at used Boxster prices and they have dropped so low that, if your 2.5L does die, it would be about the same cost to buy a used low mileage 2001 S as to do a motor swap with a new motor.
Luv2Box is offline   Reply With Quote
Old 03-09-2015, 09:14 AM   #24
Luv2Box's Avatar
The 2.7 by far is THE best engine. This goes for the 5 chain and 3 chain variants.
Last year I only saw 2 of those engines fail, and one had 190K miles on it when it popped.
How do you tell a five chain from a three chain? What would entail installing one on a '99 Boxster Tip in place of the 2.5L Tiptronic? Would it be the least expensive bang for buck replacement if the 2.5L goes? Thanks.
Old 03-10-2015, 09:06 PM   #25
Dang, I thought I was all set in looking for an 'S'.... but now I read this..............
mack73 is offline   Reply With Quote
