Old 02-17-2015, 07:03 PM   #1
Name of 16/2 bridge crimp connection
Does anyone know what this connection is called and where I can get it? Its located in the 16/2 bridge (slot 11 in front relay team). I want to run another relay that's triggered by ignition. I figures using a bridge is cleaner than tapping into a wire.
martsink is offline   Reply With Quote
Old 02-18-2015, 07:12 AM   #2
Reebuck1
Bridge Point
It has been a while but I believe the female wire connector is a VW part number # 000-979-151-EA. You should be able to get it from your VW dealer but they are not cheep. They are connected to a yellow wire with a female connector on each end.
Good luck
Reebuck1 is offline   Reply With Quote
Old 02-18-2015, 07:58 AM   #3
Go to Mouser Electronics website, or better yet, give them a call. You can send them that pic, and they will tell you what you need.
Defectfully
Patrick
Hogosha is offline   Reply With Quote
Old 02-18-2015, 08:08 AM   #4
Good luck
Thats the one, thanks! Quite a markup they have on a piece of wire with a connector
Old 02-18-2015, 12:22 PM   #5
Reebuck1
connectors
Yea, they are expensive from VW.....unreasonable!! Try the suggestion for Mouser
and let us know what you find out.
