Old 02-02-2015, 05:20 PM   #1
rdass623's Avatar
pcm 2.1 ipod adapter?
does anyone know where to find a ipod interface adapter for a boxster equipped with the pcm 2.1 system which will not require permanent modification to the vehicle?
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 02-10-2015, 11:10 PM   #2
ECU Wizard
ECU_Doctor's Avatar
I have not found a way to achieve this without doing a modification, any mod is reversible if you want it to be.
I have installed an iPod interface into my Boxster simply by tying into the ECU of the radio, I have an iPod adapter in the glove box and that is soldered onto the circuit board of the factory radio. I flashed the ECU with an iPod command, when I hit the number 6 button on my radio it powers up the iPod and brings up the menu onto the radio it self. It works very very well, and is fairly simple todo. No one will ever know what you have done with it.
ECU_Doctor is offline   Reply With Quote
Old 02-11-2015, 01:07 AM   #3
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by ECU_Doctor View Post
I have not found a way to achieve this without doing a modification ...
..., I have an iPod adapter in the glove box....
You have an iPod adapter in the glove box of your 2001 Boxster? Did you have to replace the entire dash to get the glove box?
...I myself own a 2001 Boxster, it has been my test car. Everything on my car is bone stock, with the exception of a re mapped ECU. :dance:
I'm pretty sure that reflashing the factory stereo and soldering some direct lines is a bit beyond what the OP is looking for, but I think that most of us would love to see pics, and a bit of a DIY.
Old 02-11-2015, 10:19 PM   #4
rdass623's Avatar
I ended up purchasing the Porsche music player interface. it plugs into the antenna and is basically a fm modulator. the sound quality is not all I had hoped for, so I will be doing a bit more fiddling with it in hope of getting it to work better. the music plays through the fm radio, but the sound is a bit off.
