Old 01-30-2015, 11:30 PM   #1
Rear indicator not working
I'm new to Boxster world. Just received my 03 boxster s on Tuesday. The rear, right indicator is not working and I'm getting hyper flash on the front indicator. I switched out the bulb and made sure all connections are in, but nothing is working. Any ideas?
I tried searching but came up with nothing
Thanks in advance
boxsterinjapan is offline   Reply With Quote
Old 01-31-2015, 01:51 AM   #2
Need For Speed
KRAM36's Avatar
Do you have LED lights? Hyper Flashing will happen with too many LED lights. You will need to instal a load resistor.
LED DRL Fog Light Canbus 50W 6ohm Load Resistor Wiring Canceller Decoder H1 EVH | eBay
Old 01-31-2015, 02:47 AM   #3
Thanks for the quick reply. I think the car had the hyper blink and no rear indicator before I put in the LEDs. I put in the OEM ones in to check if that was a problem but not solved.
Old 01-31-2015, 03:05 AM   #4
In general hyper flashing front indicators mean that the rear indicators bulbs are not connected to the circuit. I think you have ro check wiring, connectors and bulb sockets.
Regards
Markus
Old 01-31-2015, 06:28 PM   #5
Went back and checked all of the wires and turns out there was a loose wire. All fixed! Thanks!
