Old 01-30-2015, 09:50 AM   #1
Reebuck1
Electrical Wiring Help
I have to run wires to the back of Bridge Points BS 14/2, BS 5/2 and BS 1. Can the new wires be connected from the front of the relay socket or do I have to remove the whole relay mounting bracket to gain access from the rear? It looks like the Bridge points I need have a door on them but I am reluctant to try and pry it open. Also, does it make a difference which side I make the connection on....if the wiring diagram show the wire going into point 8 and it would be easier for me to go into point 6...does it make a big difference?
I am installing Cruse Control on a Boxster that does not have it.
Reebuck1 is offline   Reply With Quote
