Anyone recommended a place to get turbos and hardware?
Anyone know of a good place for getting aftermarket turbos and hardware? I'm building a custom 911 and will need to build everything from scratch. I've done the "Google" search already and I'm just looking for recommendations. This will be my first endeavor into building a turbo engine.
air or water cooled?
Audi 2.7T. I don't want to use K03s or K04s either. I'm thinking about going with a single turbo set-up instead. If I go that route, I'll have to make all of the exhaust and most of the intake system myself.
034efi sells the single kit
these have always fascinated me:
http://aerocharger.com/aerochargers/ no BOV, no wastegate, no oil lines. they're not 600 hp monsters (unless you get two, but that gets expensive) but look to make for a simple, clean install. ebay injectors, silicone, exhaust piping (aerocharger provides the two exhaust flanges). plumb it suck though and you might be able to use the audi ecu with some reprogramming. |
| All times are GMT -8. The time now is 08:28 PM. |
