Old 01-04-2015, 06:47 PM   #1
grimesb's Avatar
Technical Difficulties after clutch job
Hello Everyone,
I just put together my car after a clutch job and unfortunately have fouled something up with the job. I'd greatly appreciate any pointers on what to look into before paying a professional. I'd like to try and finish what I started!
Here are the main components I purchased:
1. LUK Part # DMF025 Flywheel
2. SACHS Part # K7019301 clutch and pressure plate
3. Pelican Parts IMS
4. Cat Bypass Pipes
5. New Transmission with less miles was installed ( had it available so figured why not...could one 2.7L tranny be that significantly different than the other? I was told when purchased it was from a 2001-2003 2.7)
Here's what happens when I start the car while on jack stands:
1. Car idles at about 900rpm
2. Can apply gas with no issues when not in gear
3. Once I try to place car in first gear and maintain about 1.2k rpm it sounds normal for about 4 seconds and afterward I hear a big bang that feels like something is off-balance / and or like two metal items colliding. I can feel it from the drivers seat rather well..it's bad.
3.5 When I disengage the clutch after the noise occurs you can abnormally hear the disengagement. I never heard it previously.
4. Clutch hydraulics are different..the pedal allows me to switch gears but it sits much lower than it previously did.
I made a sound clip but it wasn't an allowed format. Will make a video tomorrow.
Question: Could this be due to not mating the clutch and flywheel?
Question: The axle shafts are about 50% torqued..could that cause this noise when I put it into gear?
Thank you for your time!
-Bennett
2001 Porsche Boxster Base in all Black at 102k
DIY work so far:
- Row Kit, Tie Rods, Drop Links, Elephant Racing Control Arm Bushings, Water Pump replacement, IMS guardian, 968 Sport Seats, and Axle Shaft rebuilds.
grimesb is offline   Reply With Quote
Old 01-05-2015, 02:07 PM   #2
woodsman's Avatar
Can you get someone else to operate the clutch while you get your ear under the car?
