Old 12-26-2014, 04:44 PM   #1
I have a 01 2.7 and really want a 996 engine
Which engine is the easiest to swap in, and what all is involved. I figure I can sell my good engine for a small chunk of change, and put the rest to getting the new engine. Does anyone make mounts for this conversion? Being that I have the 01 car will I need a different ecu?
2013grandsport is offline   Reply With Quote
Old 12-26-2014, 05:43 PM   #2
Motorist & Coffee Drinker
78F350's Avatar
Read this:
Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
..and buy this:
101 Projects for Your Porsche Boxster
..and learn to search.
probably a 3.2 from another Boxster
More than anyone will post in one reply, but not too much to find and read. Consider more than just the engine: transmission, brakes, cooling...
Probaby, look in the classified section and on eBay, they may be cheaper than you think.
Engine mount (front) can be the same, but may need to be lowered. You can buy more solid aftermarket ones.
You will need the appropriate tune flashed to the ecu (DME) or get one compatible with the '01 and new engine.
...and read through the other threads that you have started.
Old 12-27-2014, 08:32 AM   #3
BYprodriver's Avatar
Rebuilt 2001 3.6 engine for sale - 6speedonline.com Forums
