Old 10-30-2014, 08:23 AM   #1
Shift linkage
So I stopped for coffee backed out of parking lot put it in first and it did not want to go felt like third gear had to slip the clutch to get going. I had two gears and the shifter would flop from side to side, no reverse, just third and fourth gear. WHAT'S MY PROBLEM???????
Wild Bill is offline   Reply With Quote
Old 10-30-2014, 08:37 AM   #2
JAAY's Avatar
Sounds like the set screw on the linkage possibly popped out of place. It is located on the passenger side in the rear behind the triangular looking aluminum heat shield. http://www.pelicanparts.com/techarticles/Boxster_Tech/37-TRANS-Drop/images_large/Pic3.jpg The set screw is the only part in the diagram with out an arrow. I think it is a 10mm head. Good luck. I hope this helps.
JAAY is offline   Reply With Quote
Old 10-30-2014, 11:10 AM   #3
Shifter linkage
Thanks Jaay I will check it out I took the center counsle out and the shifter could not find anything wrong with anything so thanks a lot!!
