Old 10-08-2014, 11:50 AM   #1
3.4 to 3.6 using 997 3.8 99mm pistons
Im doing all the homework I can into doing a 3.4 to 3.6 engine conversion.
Ive found the Wossner pistons and they list all the speca of them (OE specs)
As you are probably aware, to go to 3.6 from 3.4 requires 99mm bore. The 997 3.8 has a 99mm bore.
Can we use these off the shelf pistons for our 3.6 big bore engines?
3.4 996 spec
11.3:1 CR
15cc bowl in top of piston
32.3mm compression height.
3.8 997 99mm pistons
11.8 CR
13.8cc bowl
33mm compression height
out of interest
3.4 987 S
7.8cc bowl
11.1 CR
Does the 3.4 996 engine , albeit with a 99mm bore, accept thr 997 S pistons?
jimk04 is offline   Reply With Quote
