-   -   right front lock under hard braking (http://986forum.com/forums/performance-technical-chat/54278-right-front-lock-under-hard-braking.html)
jaykay 09-30-2014 05:43 PM
It is common for the right front to be first to squeal and lock under hard braking?
I am thinking that this has to do with driver position in a non corner balanced car and that I am stuck with this
san rensho 09-30-2014 06:04 PM
Mine does the same thing. I think you nailed it. Since there is less weight on the right front, that wheel will lock up first. Try a hard stop with a passenger and see if there is any difference.
steved0x 10-01-2014 06:26 AM
On mine the right front is usually the one that locks up first and triggers ABS activation. I have changed front rotors and stickier tires now and ABS did get a little more "symmetrical" if that makes any sense :)
jaykay 10-02-2014 09:01 PM
Sure does....more grip puts you further away from the friction threshold for that wheel.
Then you will brake a little and your tires get baked and voila!!
Your rotor comment interests me........a special pad compound for the unweighted wheel? I guess this would be something for the more recreational guys....no corner balance or bias adjustment
