09-24-2014, 08:30 AM
#1
987 S - do you fully depress the clutch?
A habit I picked up from learning stick on BMWs is to not fully push in the clutch after first gear. From what I was told by a "master tech", it was pointless on some BMWs because half way in was already full travel in the gear box. I understand however not all cars are like this.
I was wondering if anyone knew what case it is in the six speed on the 987S? Does the entire clutch travel correspond 1:1 with the gearbox or is it a similar situation where fully pressing in the clutch is pointless after first gear? I can certainly drive much smoother when I don't fully press down on the clutch after first gear.
09-24-2014, 09:49 AM
#2
On the slippery slope
Bad habit
IMHO, ya gotta push it all the way down
Should not matter what gear
Yes, like most clutches, it is disengaged before full travel, but a bad habit nonetheless
Of course you can speed shift it like any manual tranny without using the clutch at all, but YMMV
BTW, welcome to the forum
Where in SD are you located?
2004 996 Targa Tip
Instructor - San Diego region
09-24-2014, 10:59 AM
#3
Originally Posted by JayG
Bad habit
North County.
Sorry, I didn't mean just clutch disengagement. I meant in some gear boxes, it is pointless to fully depress the clutch because fully depressing the clutch does nothing because full movement of the clutch is done by XX percent.
So the last remaining X percent of the pedal travel really doesn't do anything once your above first gear. Some cars are made that way, and some not. I was wondering if anyone was familiar enough with the six speed Getrag in the 987 S to know?
09-25-2014, 03:02 AM
#4
I'm not sure what you mean, clutch engagment has nothing to do with the transmission ?
09-25-2014, 06:08 AM
#5
Originally Posted by FlyPenFly
North County.
While yes, the clutch is disengaged before the pedal is to the floor, do you have a calibrated leg?
What is it you are trying to gain? A few milliseconds in shift time?
2004 996 Targa Tip
09-25-2014, 06:23 AM
#6
Maybe I shouldn't admit this, but I made a clutch stop from a long bolt, washers and some nuts for an E36 M3 I used to own. Still fully disengaged, but cut about 2 inches of travel.
I enjoyed it, timed well with my short shifter. Wouldn't do it again - not worth the risk. However it was still well clear of any grab point for the clutch. Younger days.
09-25-2014, 11:27 AM
#7
Hah. No. Just wondering if this bad habit is as bad as I think it is or if it's a common quality among Getrag transmissions. My E46 M3 also had a Getrag six speed. It did full clutch movement at around a bit more than half pedal travel.
09-26-2014, 04:37 PM
#8
All cars are the same
It ain't rocket science.
Lots of mechanics seem to have a need to convince you they're geniuses.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
10-08-2014, 05:47 PM
#9
Registered Boxster abuser
I get lazy at times and not use the clutch at all once the car is moving. More so on motorcycles...
The clutch is only required when flywheel speed does not match the gear speed
