Old 09-19-2014, 10:58 AM   #1
Snapped the door harness connecting clip
Well, here goes…
98 Base Boxster with no door speakers. In the process of adding the wiring, the door-to-body harness was unscrewed and separated to add wires for the new speakers. The connection is a 2-point connection. On the drive's side, the top half is a "slide in" tab and the bottom half has a screw that keeps the connection secure. The passenger side is upside down but the same tab / screw connection.
Well, during the removal process, the driver's side plastic tab at the top on the BODY side was broken. Therefore, when the connection is made, the door-side connector is only held in place by the screw, and the top part with the clip obviously won't stay seated…
So - I call Porsche. The only thing they have is a harness for the body side…and it's $6k.
Plan B. Supposedly theres a part number for these connectors - but we can't find the part number on the body-side of the connector. So, at this point I'm not sure if other vehicles share the same connector (VW, Audi).
I guess I'm headed to find a vehicle that is being parted out to see if I can salvage the body-side of the connection, and then have to do the best I can to re-pin everything…
I'll try to get a pic up soon - hopefully someone has some info on the name of the connector for the door-to-body. And perhaps an idea to find an exploded diagram of that connection…
SpikeJr is offline   Reply With Quote
Old 09-19-2014, 12:16 PM   #2
Jinx's Avatar
Thumbs up Connectors
Check out EBaymotors-parts-harness connectors
Jinx
Jinx & Bill
Jinx is offline   Reply With Quote
Old 09-19-2014, 12:45 PM   #3
Jinx
Thanks Jinx - I'll head over there now...
Old 09-19-2014, 01:15 PM   #4
Found it! Thanks again Jinx!
Old 09-19-2014, 02:02 PM   #5
inveniam viam aut faciam
I have the car side connectors if you still need one.
Qmulus is offline   Reply With Quote
Old 09-19-2014, 07:15 PM   #6
Appreciate the offer - I have the one pictured above on the way. If it turns out to be faulty I'll send you a PM.
