09-11-2014, 09:14 AM
Fused spacers / rotors
My wheel spacers are absolutely fused to my brake rotors! I am assuming that my rotors will be just as bad if I can ever access them. Any good tricks other than a hammer?
Have any encountered this? I am dreading having to go search up a puller that will fit
...no I don't drive it in winter
986 00S
09-11-2014, 11:41 AM
Rubber mallet and a flathead screwdriver always works for me. Slowly chip inbetween them all around the rotor and it will separate.
09-11-2014, 12:13 PM
Suggest trying a wood block first before resorting to screwdriver.
Make sure you use anti-seize b/w spacer/rotor hat upon re-installation (same w/ rotor hat to hub and wheel to spacer, etc.)
Good luck
"Cool Prius!" - Nobody
09-11-2014, 12:52 PM
Thanks guys will wrestle with it!!
986 00S
09-11-2014, 04:01 PM
I wonder if heat would help?
09-11-2014, 05:06 PM
still plays with cars...
Give 'er **************** with a dead blow hammer, fella.
Six speed 2000 Boxster S
09-11-2014, 05:08 PM
Yes tried that!!
986 00S
09-11-2014, 05:14 PM
Douse with PB Blaster overnight and pound away again tomorrow?
09-11-2014, 05:18 PM
Yes did that but .... With wd40....as was running out of borrowed garage time!!
986 00S
09-12-2014, 06:50 AM
WD40 barely classifies as a lubricating oil...
PB, a penetrating oil, is a completely different class. Try w/ PB and let soak overnight as BS states. I've used PB to release frozen solid brake caliper slide pins, header bolts, exhaust clamps, etc. - all of which I thought were completely toast.
Good luck
09-12-2014, 07:38 AM
Heat and PB will do it.
Schedule an auto-X race and a couple days before spray the PB between the too.
Give your brakes an smoking hot workout during the auto-x.
After the racing those should separate without much problem.
The differential heating/cooling cycles with the brakes doing the heating and the wind doing the cooling should cause enough expansion to break them free.
or
Use a bigger hammer, but thats not as fun as an Auto-X.
