2.5 ECU map spike
Can anyone shine a light on what could be causing the spike in my map at 5400 rpm on my 1998 2.5.
The guy that remapped it tired is hardest to remove it but with no luck, he did say there was limitations with the early ecu's and non e-gas throttle. car goes well but you can feel a little hold in the power at that point before it pulls again to the red line. Also it only in 4th & 5th you notice it the most, 1 2 and 3rd are fine. http://986forum.com/forums/uploads01...1410397369.jpg |
Can anyone shine a light on this
What mods did you do before the map took place?
I presume you know of Boxsa.net where someone who had used the same tuner might tell you of their experiences. |
Mods ive done are Full exhaust system, no cat's 996 throttle body Cone air filter (sealed from engine bay heat) 4" Underdrive pulley Lightweight flywheel 4 Bar fuel pressure regulator l'm i right in saying that the two spikes at 3700 rpm & 5400 are where it comes on & off the variocam |
| All times are GMT -8. The time now is 05:31 PM. |
