Old 09-08-2014, 07:05 PM   #1
RayW's Avatar
Rotational chirp, not belt related??
So, I'm hoping this is a known issue with Boxsters. I bought mine with a chirping sound that I swore would have been the throw out bearing. I changed it, along with the clutch, pilot bearing, and the IMS as long as I was there. The IMS with 100K was still perfect... Anyway, I ruled out belt / pulley noises by disconnecting the belt and running the engine, the noise is still there. The car is quiet on a cold start up, the noise will start coming on after about 5-10 minutes running. The noise will also go away at around 1500-1800RPM. It is primarily there at idle. Does anyone have any thoughts as to which direction to go to figure this out?
RayW is offline   Reply With Quote
Old 09-08-2014, 08:39 PM   #2
Topless's Avatar
Loose spark plug? It's a fairly common problem that often gets overlooked. Also possibly a worn timing chain guide can cause a chirp.
Old 09-09-2014, 01:51 PM   #3
RayW's Avatar
Thanks for the tips. I'm back at it tonight with a stethoscope to see if I can at least locate the area the sound is coming from.....
Old 09-09-2014, 03:25 PM   #4
boxster6354's Avatar
I am just going to ask, you did check for a ..............
Good Luck
Old 09-09-2014, 03:29 PM   #5
RayW's Avatar
Thanks, first thing about this that made me laugh
Old 09-09-2014, 04:31 PM   #6
I'd second the spark plugs. If they haven't been changed in a while might be good to do them. Not a bad job with the proper tools.
Old 09-10-2014, 05:43 PM   #7
spark plugs for me too, had the same fault, found 5 of the 6 plugs lose
whitecliffs is offline   Reply With Quote
Old 09-10-2014, 05:51 PM   #8
