Old 08-30-2014, 12:11 AM   #1
is this a window regulator problem?
Hey guys
I have searched the forum and have come to the conclusion that I have a problem with the window regulator. But before I go ahead and buy the regulator assembly, I just want to make sure that's what this is.
My driver side window just suddenly failed.
It is stuck in the fully up position. It doesn't drop with internal door handle pull, or external door handle pull, or unlatching of the convertible top. If I press the window button, I hear a whirring noise from the door, but the window doesn't drop.
Does this sound like a broken window regulator problem? Thanks.
--1989 Mazda MX6 GT
--1997 Porsche Boxster
--2005 Lexus RX330
--2007 Maserati Quattroporte Sport GT
Jinster is offline   Reply With Quote
Old 08-31-2014, 06:44 AM   #2
They were born to break, and it's very common for then to go out. I would suggest taking your door panel off and taking a look. It only takes about ten minutes to get the whole window regulator/motor out. .
Old 09-01-2014, 04:57 PM   #3
Yeah. The car is 17 years old.... It's about time. I ended up just buying the regulator assembly on spec. I don't want to keep taking the car apart. The panels become loose and rattle if I do this too often.
--1989 Mazda MX6 GT
--2005 Lexus RX330
