Old 08-11-2014, 12:16 PM   #1
Power Window issue
My passenger side window is stuck and won't open or close - it's stuck open about an inch.
After purchasing and installing a new motor it still will not engage. I plugged the new motor into the Drivers side connectors and it works so no problem with the motor (the old motor works too).
The window control switch works
The fuse in D1 is good
Has anyone experienced a similar issue? It's a 97.....trying to avoid the dealership.
Best,
Marty
Marty97 is offline   Reply With Quote
