Old 07-08-2014, 12:13 PM   #1
Another tire question
So I've been searching the forums and it seems plenty of folks are running wider than stock tires up front on factory 17s. I was wondering if any one had considered trying to correct the factory "built in" speedo error with slightly larger tires.
My calculations show that 225/55/17 and 265/45/17 (255/45/17 would be close as well) would give me a much more accurate speedo (its conservative by about 4 mph on the highway). Has anyone tried this? Will it have affect ABS function?
shadrach74 is offline   Reply With Quote
Old 07-08-2014, 03:47 PM   #2
Track rat
Topless's Avatar
On a 986 it might work but the 8% loss of torque from effectively up-gearing would overshadow the benefit of a true speedo for me. Tire choices are also somewhat limited in those sizes. I'll pass.
Old 07-08-2014, 04:40 PM   #3
Very few manufacturer make factory 17" tire sizes let alone the sizes that you listed which I'm fairly positive nobody makes 265/45/17. Part of the reason why I went 18"s.
Old 07-09-2014, 03:04 AM   #4
If you have PSM, making the front taller relative to the rear can cause issues with the traction control.
Old 07-09-2014, 03:45 AM   #5
Good info to have! However, I specifically sought out a non-PSM car.
Old 07-09-2014, 03:52 AM   #6
True. I have found a few 265/40/17s that should work. This would only be 1.6% difference in diameter and would bring speedo accuracy to within about 2.5mph.
