Old 06-15-2014, 01:39 PM   #1
4" UDP...2100 belt too short
So all the sources I have looked at regardinfg belt length witha 4" UDP states 2100mm. (With AC and PAS). well for me this bekt is way too long.
Anyone any more feedbak on this.?
Im thinking maybe 20 or 30mm shorer?
jimk04 is offline   Reply With Quote
Old 06-16-2014, 07:08 AM   #2
Your message subject title says the belt is too short but in your text you say it's too long.......which is it ?
rfuerst911sc is offline   Reply With Quote
Old 06-16-2014, 02:34 PM   #3
Does the OEM belt not fit? I thought it was supposed to?
Old 06-17-2014, 12:52 AM   #4
Steve Tinker's Avatar
No - the smaller pulley demands a shorter belt.....
When I bought mine from Jake Raby, it came with a correspondingly shorter belt.
2001 MV Agusta F4.
Old 06-19-2014, 01:09 AM   #5
Sorry yeah....Too long or short....?
I meant long....but have found a 2075 is correct.
Dont understand all the references to 2100 I've seen....way too long for me.
Old 06-19-2014, 05:42 AM   #6
I'm curious is 4 " considered the " standard diameter " for under drive pulleys ? Or do different manufacturers make different diameters ? If there are different diameters that could cause confusion on what size belt is considered the correct size. I'm having Jake install a UD pulley in August ( damn he's busy ) and I will pay attention to the brand/size of belt that is installed.
Old 06-19-2014, 12:25 PM   #7
May I inquire as to where you acquired the 2075 belt? I am having one installed next month and sounds like I will need this belt.
Old 06-19-2014, 02:34 PM   #8
Just a local motor spares shop....gates 6pk2075 if I remember the part number .
