Old 06-10-2014, 05:21 PM   #1
Front wheel bearings
So I bought a Sir Tools B-90 P2 last fall from another forum member. Plans to change all four bearings in a couple weeks. Question is, anyone have experience doing the fronts with this tool? There's a post on Rennlist, not very descriptive but sounds like this will work with hub still on the car. User states you need to loosen the shock mount to drop it enough to get the front spindle out, but it works. Oh, and excited to remove secondary cats so I can drop the rear axles, got a set of Top Speed bypass pipes to install... w00t!!!
psquared39 is offline   Reply With Quote
