Throttle position and Durametric
Can one get throttle position data from durametric with just the ignition on. I want to be able to verify that the full range actuation is available and adjust stop(s) prior to ever running the car. Will this plan be messed up with the automatic TB calibration sequence?
Yes I have made cable cam measurements. I am trying/planning to verify throttle pedal set up in this manner once I get there. Yes....at present I am not able to just try it... |
On my 01 S I can get throttle position with ignition on, but its the e-gas electronic throttle.
No idea about non egas models. Do you know about the throttle adaptation proceedure after resetting fault codes or diconnecting battery. Ignition on for 60 seconds without touching throttle, then 10 seconds off, then start the car. |
Thanks for the info ....helps a lot!
worked like a charm |
| All times are GMT -8. The time now is 11:38 AM. |
