Rennline fully adjustable pedal install rev 4
Has anyone completed this installation?
I have everything all built but cannot seem to hook the pedal box on to the base plate t-slot.....if you have done this work you will know what I am talking about....do I have to start filing...something? |
On my pedal, I had to file a bit on the plastic foot that hooks the pedal box to the t-slot. I think the rennline metal plate that surrounds the box is a bit too thick so the unmodified foot can't extend down far enough. I opened up the slot in the foot so it would engage the t slot properly.
At least that's what I remember. I did the install last fall, so things have gotten a bit foggy. Check and make sure this makes sense before cutting anything! |
| All times are GMT -8. The time now is 11:39 AM. |
