Old 04-21-2014, 08:14 AM   #1
Alien's Avatar
Flywheel Re surfacing
My apologies if this question has been asked before, But I have a flywheel from a 2001 S that has some minor grooves in it. My question is "Can it be re surfaced"?
The 101 project book suggests no, but that be may aimed at persuading people to buy an new one. With it being made in two pieces, I would block the movable part from beneath then clock it so its level before surface grinding.
Thanks - Andy
Alien is offline   Reply With Quote
Old 04-21-2014, 09:23 AM   #2
Registered Boxster abuser
healthservices's Avatar
Short answer... yes
whether it is recommended is subject to debate.
I have had it done recently with out issues.
pricing can be anywhere from $75 to $450 depending on how greedy the machine shop is.
Old 04-21-2014, 10:58 AM   #3
Benjamin's Avatar
You might have trouble getting a surface grinder in there without hitting the timing teeth. The few (non-Porsche) flywheels that I have seen resurfaced were just face milled and not ground.
2000 986 S - "The Black Widow"
Benjamin is offline   Reply With Quote
Old 04-21-2014, 11:55 AM   #4
Engine Surgeon
In my experience by the time a DMF unit needs to be resurfaced its very near maximum deflection of the two masses and should be replaced anyway. Kinda like putting lipstick on a pig to resurface one.
US Patent 8,992,089 &
US Patent 9,416,697
Old 04-21-2014, 12:20 PM   #5
Alien's Avatar
Thanks for all your comments. Jake, You have a good point, however I'm on budget and would be doing the work myself
Old 04-21-2014, 04:23 PM   #6
Jake,
Would you recommend re-surfacing and then balancing a 'New" DMFW..?
This is to remove some of the inertial weight (not quite like a LWFW), but end up with a lighter than a standard dual mass flywheel.
Your comments are always appreciated, thank you.
