03-26-2014, 05:07 AM
Boxster S - Rear Strut Failure?
I have a Boxster S 2003. Recently, while driving it started to make a weird noise, upon inspection I discovered there was a nasty cut on the left rear tire( see pics ). When I got home, I took the tire off but I couldn't find anywhere that would be rubbing against the tire to make that nasty cut, the closes thing was strut/shot. Could this be a Strut Failure or is it something else?
How much does it cost to replace the struts dealer vs indie shop?
Any info greatly appreciated.
(This might be a repeat post. I posted earlier but couldn't find it in the list)
03-26-2014, 08:27 AM
That's just the tread seperating from the tire carcass. Looks like it was caused by alignment being out. you just need tires & alignment. Check struts for leaking fluid or replace if over 80,K miles.
03-26-2014, 09:57 AM
+1 alignment out
03-26-2014, 07:43 PM
Phew.. I thought it was something more serious... Thanks guys!!...
03-27-2014, 10:00 AM
Oh.. it *could* be more serious, like a bent upright. Is the car lowered? I see this when people think 5mm's of toe in is "OK" after they have lowered a car and realized they cannot adjust the toe far enough with the stock rear toe link.
03-28-2014, 08:35 AM
Also, you were pretty brave (or foolish) to continue driving it home after seeing that (unless you were a couple of blocks away and on a slow road). I would have immediately put the spare on.
As to your shop questions, I always use indy shops with good Porsche reputation. dealers are never a good deal if you are out of warranty. Likewise for parts - buy from the known vendors. Dealer mark ups tend to be very high.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
