Old 02-21-2014, 02:26 PM   #1
CPU Cut In Horsepower?
I have an '03 Boxster S with a slow leak in one of the rear tires. When it gets down around 25psi the car feels as if its lost 30% of its power. Pump it back up to 36psi and it feels normal but not immediately.
The only explanation I could come up with is that the car thinks its on ice or in mud because one wheel now has a smaller radius and rotates faster. I don't have a manual for it so does anyone know if these cars had such a thing?
2003 Boxster S
2007 VW GTI
1967 Alfa GT Sprint Veloce
1965 Mini-Cooper S
1966 Triumph Bonneville
mrtoad3 is offline   Reply With Quote
Old 02-21-2014, 03:14 PM   #2
There Is No Substitute.
rick3000's Avatar
If you have a 'TC Off' or 'PSM' Button on the dash you have traction control. I am not sure it would affect the performance that drastically.
I think your problem is that you are running one of your tires -10psi from where it should be which will affect all kinds of things like mpg, speed, stability, etc. Repair or replace the tire.
Old 02-21-2014, 03:48 PM   #3
It doesn't take much of a diameter difference for the PSM to kick in. Fix that tire !
Old 02-21-2014, 05:26 PM   #4
Gone
Davev's Avatar
I had a 2006 Mercedes and my wife had a slow tire leak. She rolled into a tire center- they put on a new tire. Same brand. Shortly after that she reported the car was not running right- she would start to pass someone and the power would drop off.
After this went on for a while - I took the car and it was crazy- any acceleration and bingo- power drop. We took it into the dealer- after a few hours they found the tire size was off by one size down. Easy fix.
So fix it
Davev is offline   Reply With Quote
