02-10-2014, 11:53 AM
#1
Replacement engine question
When a new crate engine is purchased from Porsche does it come complete with the the intake distributor, distributor tube and resonance tube?
John M
02-10-2014, 12:14 PM
#2
Crate engines usually dont come with anything except for the block, heads, and valve covers. All the misc stuff like brackets can vary from year to year, so you switch them over from your engine
02-10-2014, 10:43 PM
#3
02-11-2014, 04:14 AM
#4
Replacement engine 987
Thanks, anybody got a build sheet like that for a 987?
John M
02-11-2014, 07:07 AM
#5
Originally Posted by teleski
Definitely not the same today. Remanufactured engine from Porsche includes everything bolted directly to the engine. When you remove the engine the replacement will have the same parts attached. Intake manifolds, SAI except the pump, A/C compressor, flywheel & clutch if manual trans, exhaust manifolds. What do you expect for $20,000. + core charge.
02-11-2014, 07:51 AM
#6
Sorry, but just to be clear are you saying the intake manifold crossover tubes are included in the new engine?
John M
02-11-2014, 08:01 AM
#7
Yes, every part of the intake, fuel rails & injecters, new throttle body, I think.
02-11-2014, 05:53 PM
#8
14Gs Bypro 14.........on sale that is.
02-14-2014, 01:51 PM
#9
Wow 14Gs, thats a big drop. 1 year ago my 3.2L was going to cost $20000 +.
02-14-2014, 05:06 PM
#10
Engine Surgeon
If your car is an 03-05 S then I have something for you.
US Patent 8,992,089 &
US Patent 9,416,697
