Old 03-26-2014, 06:07 AM   #1
Boxster S - Rear Strut Failure?
I have a Boxster S 2003. Recently, while driving it started to make a weird noise, upon inspection I discovered there was a nasty cut on the left rear tire( see pics ). When I got home, I took the tire off but I couldn't find anywhere that would be rubbing against the tire to make that nasty cut, the closes thing was strut/shot. Could this be a Strut Failure or is it something else?
How much does it cost to replace the struts dealer vs indie shop?
Any info greatly appreciated.
(This might be a repeat post. I posted earlier but couldn't find it in the list)
rolegs is offline   Reply With Quote
Old 03-26-2014, 09:27 AM   #2
BYprodriver's Avatar
That's just the tread seperating from the tire carcass. Looks like it was caused by alignment being out. you just need tires & alignment. Check struts for leaking fluid or replace if over 80,K miles.
Old 03-26-2014, 10:57 AM   #3
Brad Roberts's Avatar
+1 alignment out
Engine Builds, Transmission Builds, Engine Conversions, Suspension Installs, Suspension Tuning, Driver Coaching, Data Acquisition, Video, SCCA/PCA/POC/NASA/GRAND AM/ALMS.
We have worked with amateur and professional drivers for over 26 years. In house machinist, In house fabrication. Our cars, our parts, our engines, our transmission's run nationwide at events every weekend. We work side by side with industry names developing parts.
Brad Roberts is offline   Reply With Quote
Old 03-26-2014, 08:43 PM   #4
Phew.. I thought it was something more serious... Thanks guys!!...
Old 03-27-2014, 11:00 AM   #5
Oh.. it *could* be more serious, like a bent upright. Is the car lowered? I see this when people think 5mm's of toe in is "OK" after they have lowered a car and realized they cannot adjust the toe far enough with the stock rear toe link.
Old 03-28-2014, 09:35 AM   #6
linderpat's Avatar
Also, you were pretty brave (or foolish) to continue driving it home after seeing that (unless you were a couple of blocks away and on a slow road). I would have immediately put the spare on.
As to your shop questions, I always use indy shops with good Porsche reputation. dealers are never a good deal if you are out of warranty. Likewise for parts - buy from the known vendors. Dealer mark ups tend to be very high.
Ed
Pittsburgh, PA
78 5 spd 928 Blumaxx (in Hemmings S & E issue #100)
85 928S garnet red stock daily driver
06 Mustang GT Legend Lime and modified to go even faster
linderpat is offline   Reply With Quote
