Old 12-26-2013, 03:58 PM   #1
Lean running condition
I am getting persistent 1128 and 1130 codes. The duramteric shows fuel trims (FRA, RCAT) at the max, 4.5+. Also, the MAF flow is as 9-10 kg/min, where before, it was around 13.5 (spec is 15 +/- 1.5). I've installed three different MAFs and they are all around 10, so I'm ruling out the MAF as the culprit.
I think its pretty clear I have a vacuum leak. I've sprayed carb cleaner on most of the vacuum lines and connections behind the MAF, but I haven't been able to detect a vacuum leak.
Is it possible that a failed AOS will cause a vacuum leak and 1128 and 1130 codes? If so, can I test the AOS by disconnecting the AOS connector at the throttle body and plug everything up, then if the MAF flow readings go back to normal, the AOS is the cause of the vacuum leak?
Another code I am getting is a failed evap valve. Will a bad evap valve cause a vacuum leak?
This is driving me crazy.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-26-2013, 04:04 PM   #2
Most definitely..................
Old 12-26-2013, 04:28 PM   #3
Can I check if its the evap valve by pinching off the vacuum hose to the motor and seeing if the MAF values go up?
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 12-26-2013, 04:35 PM   #4
Oh, and will a failing AOS also cause a vacuum leak?
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 12-26-2013, 06:15 PM   #5
A failing AOS diverts vacuum to where it should not be; try pulling the oil fill cap while at an idle, if it comes off very hard (or not at all) the AOS is toast. We made a test fixture from a brand new oil cap and a vacuum gage that reads 0-20 inches of water; a good AOS should read about 5 inches of water, any higher than that and it needs to be replaced.
Old 12-26-2013, 06:18 PM   #6
Not always as it would depend upon exactly where the leak(s) is(are). Sometimes you simply have to break down and check it with a smoke machine.
Old 12-26-2013, 06:20 PM   #7
Oil fill cap comes off easily and the vacuum is very mild, i can hardly feel it when i put my hand over then oil filler tube but I have been getting more smoke at start up lately. Today it was a pretty thick, whitish blue smoke.
So a failing AOS will create a vacuum leak?
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 12-26-2013, 07:52 PM   #8
Track rat
Topless's Avatar
Check your gas cap. A bad gas cap o-ring can cause evap codes and possible a lean condition.
Old 12-26-2013, 07:52 PM   #9
Yes in a way, a working AOS has a low vacuum signal (~5 inches of water) in the engine case, a blown AOS can sometimes be as high as 25 inches of water, which is why it pulls oil into the intake system, which can operate at 25 inches of mercury.
Old 12-28-2013, 09:19 AM   #10
Ok, so I'm making some progress. I pinched off the evap system hose that connects at the throttle body and the MAF values went up to normal, around 13-14 kg/hr, and the fuel trims came down to around 2-3,so it seems the vacuum leak is in the evap system. So which valve should I replace, the shut off valve at the fuel filler or the valve under the left side of the intake manifold? And if it's the valve under the intake manifold, is there a write up on how to do it?
I have had two codes, major leak at the fuel tank ventilation system and PO466, canister shut off valve failure.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 12-28-2013, 10:57 AM   #11
I'd start with the canister shut off valve code first.
