Old 12-23-2013, 10:52 AM   #1
flete25's Avatar
Tires & Rims Question
Hi guys i am new to the site and i need your help...!!
I have a 2003 boxster based...
i want to change my rims to 19's i like to put the following
19x8.5 42mm offset ( 235/35/19) fronts... do i need spacers? if so what size ?
19x10 58mm offset (275/35/19) rear....do i need sapcers ? if so what size ?
if this is possible please give me your input....thanks !
flete25 is offline   Reply With Quote
Old 12-23-2013, 02:21 PM   #2
^ second this guy, I just joined the site and need help finding rims and finding the correct tire size.
I'll post my question elsewhere but I have another question for here, would spacers reduce reliability and performance?
Black on Black 2001 Boxster Base
Clutch Masters Stage III Clutch
Luk Flywheel // IMS Retrofit // Rear Main Seal
alanqning is offline   Reply With Quote
Old 12-23-2013, 02:32 PM   #3
flete25
I went digging around the forum, I found this post:
Originally Posted by WhipE350 View Post
Any of those would be great! Let me know when they need the Autobahn Glanz magic, least I can do for those great overlays.
Tuanle16 - This is a good link for calculating fitting: Wheel Offset Calculator
I still think these are the nicest:
I don't know much about rims, can anyone help me understand how to use the calculator? And what dimensions I should look for with a 986?
FYI: I'm lurking through this post to find some nice rims I want that would replace the honeycomb design I'm looking for, without much luck
Old 12-23-2013, 03:35 PM   #4
Johnny Danger's Avatar
Originally Posted by alanqning View Post
flete25
I have responded to questions extensively on this forum regarding wheel fitment. What specifically are you trying to accomplish ?
Old 12-23-2013, 03:49 PM   #5
A link to a thread I should read please. I try to find older threads but might not be searching the right terms.
Old 12-23-2013, 06:47 PM   #6
Wheel Clearance
Old 12-23-2013, 07:10 PM   #7
What about specifics for the 986, the backspacing, offset, and width allowed.
Old 12-23-2013, 10:04 PM   #8
2002 Boxster S
I'm sorry I didn't note where this came from, but it shows what Porsche thinks will fit a 986. Obviously, there are other wheels that can work, but this is the baseline.
2009 Carrera S cabrio
ex-2002 Boxster S, Arctic Silver, Aerokit II
silver-S is offline   Reply With Quote
Old 12-24-2013, 06:47 AM   #9
The 3mm rim offset difference, does that really make a difference?
Also, wouldn't wider tires be better for performance?
Old 12-24-2013, 06:59 AM   #10
I believe I read the limits on a 10 x 18 tire would be 295 / xx / 18. Anyone to verify that?
Would that wide of a tire be detrimental to performance?
Old 12-24-2013, 12:32 PM   #11
Depending upon how aggressive you want your fitment to be, as well as what your suspension set-up is, here's a basic outline to follow:
Fronts:
8 inches wide = offsets ranging beginning with +40 to +35
8.5 inches wide = offsets ranging from +45 to +40 or so.
Rears:
9.5 inches wide = offsets ranging from +40 to +35
10 inches wide = offsets ranging from +45 to +40 or so.
Again, these are based on a number of fitments that I have experiment with personally, and fitment between vehicles can vary based on suspension set-up, tire size and application of use.
Old 12-25-2013, 04:15 AM   #12
flete25's Avatar
danger : your are right on the money with your info...i have done alot research and it all comes back to what you just described...!!
