As promised, B&M Short Throw Install Walkthrough
As promised, here is a walkthrough for you guys on the B&M shifter install in the boxster.
http://www.turbo911.com/showthread.php?p=1426#post1426 |
Doc,
Thanks for sharing your wealth of knowledge! It's guys like you that make this such a great, fun and informative forum. I know it must have taken a lot of your valuable time to stop and take all those great pics that really help inspire us novices to attempt a project we might otherwise pay to have mechanics like you do for us. Thanks for your generosity! |
Thanks for the detailed information, time consuming, we understand.
It is my pleasure :)
Thanks as always Doc.
We appreciate your input here. :cheers: |
the gear box is the one thing I don't like on my 2000 S. I don't hate it but it feels kind of old school after having driven the S2000 a few times. My last car was a Miata and I really really really hated the notchy shifting and tried to mix all sorts of redline grades to get the notchiness to go away. At temperature it was great, better than the 6speed Boxster for sure, short throws and little resistance.
But on cold days that thing was like a rock in your shoe. Very distracting. never having driven the B&M is it safe to say that you are shortening the throw by increasing the notchiness with the short shift kit? |
Our local group does not do it the exact same way. And we have never removed the front center console for a short shift install.
We just let Madam No Fear go to town. The star of our DVD. |
Yes, I have gone back, looked at the pictures and see that. Porsche also says that you need to remove the passenger seat on the boxster, but not a 996. Never did that either.
Never asked Aileen how long it takes to pull the parts in and out. Or I would get a slap. But I do know how to put in a short shifter. B&M, and the other flavors. Thanks for your help. What do you see in the second picture of this post? |
Yes, one half correct.
The green thing. The plastic green plastic plate. What is the purpose? The evo shift link was too easy, now that I think about it. |
I must say, i have not seen the green plastic piece in any of the 25+ boxsters/996's that I have done, so I wouldn't know the purpose. Hmmm interesting.....
The green plate is on the 5 speed 986s but not on the 6 speed for some strange reason. B&M says to remove the plate if it is present. If we do not remove the plate then it gets hit by the black cable connector once the B&M is in.
The 986 has 2 part numbers for the shift tower. 1 for the 5 speed and the other for the 6 speed. The only difference is if it comes with the green plate. The plate has the 5 speed part number on it. But if you remove the plate there is the 6 speed part number under it! Some 996s come with the green plate. I forget which ones, but I think the turbo and GT2. The C2/C4 does not come with the plate. None of the mechanics at my local dealer can figure out the purpose of the plate, or why the 5 speed has it but not the 6 speed. |
I know the TT996's do not have the plate either. I have done literally 25 of these between 996C2/4, TT's, and boxsters, and have never seen one. Very interesting. I don't know that i have done any 5 speed boxsters off the top of my head though.
Here is a GT2 we worked on with the green plate.
Hi, Agreed 100%. It's simple physics - Shorten the Throw and you lose a whole lot of Mechanical Advantage - the Shifter is basically only a Lever. The Trade-off with virtually ALL Short Shift Kits is an increase in the Effort needed and a more noticable Notchiness. Any reports to the contrary are usually due to Placebic effect. The only real place you can truly shorten the shift is at the Selector Forks inside the Transmission - can't do that for a mere $150... Happy Motoring!... Jim'99 |
So how about if they made a long shift kit? You know instead of shorter they made it longer, kinda old school like in a late 70's 911? I might give that a try.
I noticed the shifter in GCT sits nice and high. I think I would like that in the boxster. |
Hey Doc, I have this pain in my wrist whenever I am in gear. Forget the pain, but I'm more concerned about the gear. LOL.
I was wondering if the B&M will fix my problem. You see, when I'm in Gear, for example 3rd, I can move my stick left and right about 1/2" ( It really feels like 1-2"). It's like it's loose as if it were in neutral. Very annoying. Do you think the B&M will take care of my problem? |
That sounds like a cable is way out of adjustment. Both the stock shifter and the B&M should be tight side to side. If you want the cheap fix, i would pull apart your console and try adjusting the cables and test it out (you can make the adjustments with the shifter in place until if feels good, then put the console back together)
I have the same problem! But in neutral its tight. It also slips into gear without any play. However once in gear there is a lot of side to side play. Can that be fixed?
I've got a 99 coming in tomorrow with a stock shifter. I will play around with it and see exactly how much play is normal. Then i will compare it to Josh's, which has the B&M in it.
Advice please! |
As a counter point to all the people who seem to love the B&M short shifter read this thread
http://986forum.com/forums/performance-technical-chat/4441-vertex-schell-short-shifter-review.html A short shifter isn't for everyone IMHO. |
Here is a good install link for the B&M Short Shift Kit:
http://www.bmracing.com/media/products/pdf/67.pdf |
Any luck Doc? Do you have any updates for us? :D
2003 GT2 Shift Assembly
Has anyone installed a GT2 Shift Assembly in their 986? I was wondering if it would be an improvement like the 997/987 assembly. Thanks in advance.
| All times are GMT -8. The time now is 12:09 AM. |
