Old 08-24-2013, 11:54 AM   #1
Main radiator fan blown fuse x3
My main radiator has blown a fuse 3 times in the last year. And this is after I replaced the fan and the resistor a while back.
Thoughts?
Old 08-25-2013, 12:19 PM   #2
Really? 36 views and not one idea?
Old 08-25-2013, 02:35 PM   #3
looked into the radiator blower electrical, found there's two circuits. one for the left and the other for the right radiators.
I hate "swapping", but might you swap out the fan and resistors (relays) from the right to the left?
if the same side "blows its fuse" then most likely a loose connection.
(motor being a power device, it will suck as much current to run. if the wiring developed an additional resistance, the motor sees less voltage and therefore demand higher current)
sb01box is offline   Reply With Quote
