-   -   HELP - Water, Oil, Fuel Indicators after removing battery/cluster (http://986forum.com/forums/performance-technical-chat/47692-help-water-oil-fuel-indicators-after-removing-battery-cluster.html)
Tall_Paul 08-12-2013 02:00 AM
I really hope someone can help with this and that its a simple fix...I recently disconnected the battery and unplugged the instrument cluster to install a mic in the dash.
When I pugged it all back together and reconnected the battery the dash now comes up with 4 warnings;
Failure of Outside Temperature Indicator
Failure of Oil Indicator
Failure of Fuel Level Indicator (Drive to Workshop)
Refil Washer Fluid
I know the fluid levels are all fine - is there a fuse that has gone?
Cheers in advance...
