Old 08-05-2013, 07:02 PM   #1
Send a message via Yahoo to Chard
Do I need a reflash on a 2000 with test pipes?
I am thinking about going catless on my 00 3.2. I was under the car this past weekend and verified I have 2 O2 sensors on each side of the car at the front cats (4 sensors total). I didn't see any sensors at the rear cats.
I am assuming I will get a CEL if I replace the headers with catless ones. Has anyone had success with the angled spacers at the rear O2 bungs? I'm in Hawaii and am not sure where I'd go for a RoW flash here.
Present:
'08 e90 335i, '00 986 S
Past:
'99.5 B5 A4 1.8tqms, '02 e46 m3 convertible
Chard is offline   Reply With Quote
Old 08-05-2013, 07:44 PM   #2
Moderator
You will indeed get a check engine on the primary cats. The secondary cats are not monitored, so if you choose to go with a different setup other than stock you will not have any problems. People have had success with O2 spacers, however the flash is pretty much guaranteed albeit much more expensive.
Old 08-06-2013, 04:45 AM   #3
DIY extremist
black_box's Avatar
Your car will smell bad at idle if you run catless without a tune. It will, though, sound wicked (if you like raspy and waking the neighbors) at high throttle openings. Ask me how I know...
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
Old 08-10-2013, 04:45 PM   #4
I've searched some more about this and read that some people are plugging the rear o2 bungs and hanging their rear sensors somewhere under the car with success. Can anyone confirm that the rear O2 sensor doesn't affect fuel mixture? That doesn't sound right to me...
I'd hate to try this out only to find that the car runs worse than stock.
Another consideration is getting an aftermarket sport cat but putting it further down the system, basically near where the 2ndary cats are, and hooking up the O2s there. Isn't that how the RoW exhausts are setup? Where could I get extended O2 sensors?
It sounds like regardless of CEL, the catless headers will yield a slight performance gain but will yield even more if paired with a RoW tune, correct?
Present:
Past:
Old 08-10-2013, 05:19 PM   #5
Johnny Danger's Avatar
Trying to source high quality sport cats (i.e. HJS or Emetec 200 cell) can be very ex$pensive. Moreover, you'll need to find a very competent exhaust fabricator who can make you a set of secondary pipes and weld the cats in place. Again, a very ex$pensive proposition. If you're trying to improve upon the oem system, perhaps the most effective way to do this - is with either the M&M Germany or Fabspeed headers /w sport cats, and delete the secondaries altogether.
