Old 07-07-2013, 05:21 PM   #1
Verhag's Avatar
OBDII; Durametric help
Ready to invest in Durametric. Not sure what I model will work best for me. I would like something I can use on both cars....97 C4S and 2000 Boxster S
Suggestions?
1997 C4S
2000 Boxster S
Verhag is offline   Reply With Quote
Old 07-08-2013, 12:14 PM   #2
For two cars the enthusiast is probably your best option. It is less than half the cost of the pro version and can accommodate up to 3 cars. However, if you are planning on buying more than one more Porsche then you should likely get the pro version which does not limit the number of cars it can be used on.
'99 black 986
Old 07-08-2013, 01:50 PM   #3
Buy the enthusiast and you can always pay the difference to upgrade to pro later should you need to
Ian c is offline   Reply With Quote
