Old 04-19-2013, 04:00 PM   #1
Question window inop
1998 boxster passenger window will not go up after safety inspection.
operated emergency flasher, turn signals etc. can hear relay click ?
when starting the ignition key must be pulled out of switch a bit.
also A/C running running when problem was noticed.
changed out center window switches they appear to be OK.
heavyevy is offline   Reply With Quote
Old 07-04-2013, 05:10 PM   #2
Same thing just happened to me yesterday, can also hear the relay click.
Any luck with a resolution?
blt2spd is offline   Reply With Quote
Old 07-05-2013, 04:18 AM   #3
I don't know whether heavyevey resolved the problem, but it certainly sounds as if the ignition switch needs replacing. There are various threads on the issue/s caused by the same and on the fix. Fortunately, not expensive although a back breaker to get at. Good luck!
Brad
southernstar is offline   Reply With Quote
