Power Steer hose removal
Anyone out there have experience removing the hose that attachs to the rear on the pump reservoir? It seems to be a pressure fitting. Before I attempt to replace the pump I'd like to see how the hose removal is done. thanks in advance for your help and advice
Are you referring to the pressure line or the return line? The pressure line is the one that connects right behind the pump pulley.
| All times are GMT -8. The time now is 04:05 PM. |
