Not debating min. thickness, but here's nothing wrong with new pads on an unresurfaced rotor, as long as it's worn evenly, and isn't grooved. I've done it for 20 years on multiple vehicles, including a race car. After normal bedding in, they're as good as new. I've never found someone who would skim cut a rotor, they always take too much material.
Fear of reusing a serviceable rotor without resurfacing is pretty unfounded. It happens 50 times a day at racetracks around the world without incident. It won't have that "perfectly smooth, all new components feel" but it stops the car just fine. |
In my experience, whenever I put a used rotor on the lathe, its usually worn unevenly or warped. This causes vibration and causes the pads to become noisy. The groves in the rotor overheat the pad ( since maybe 40% or 50% of the pad is making contact with the rotor until it breaks in ). Can you get by if you slap new pads on an old rotor? Probably. Will you get cancer watching your food rotate in your microwave from the radiation coming out of it? Maybe, maybe not. Should you accuse a shop of being money hungry because they want their client to do the job correctly? Absolutely not. |
What happened? I walked - can't afford that for just a brake job at this time, or anything else on their list that I got done for 25%-35% less at another porsche mechanic who is much more laid back about this stuff. Regardless, I have a brake pad light on and compromised safety with a car that is off the road during prime top-down weather. Which is the better scenario for that customer on the road a few months later? I presume the "can't afford to drive a porsche" argument will be used against this statement. Maybe they are right in their recommendation--I'm not going to say they are flat-out wrong--they aren't. However, their "go oem or go home" attitude is well noted in the local community, and a turn-off for lots of customers. |
I always replaced pads without even resurface the rotors. And usually it was ok. Each rotor took like 3 to 4 pads before wearing out of factory spec (on the Alfa Romeo that I had). I never used race performance pads (unless on motorbikes), just regular road use Ferodo or Brembo ones. The Brembos usually were better, but they ran out sooner too. On my motorcycle, I had a problem with the 2nd pair of pads, they started to vibrate a bit under slow breaking.
I am in total agreement with re-using safe(within spec, no cracks, etc.) rotors with new pads. Even unturned, in-spec rotors should do no more than wear the pads a bit faster.
But - We live in a liability paranoid world so if I were a shop, new pads, new rotors would be the standard job. I don't even think a customer signing a release (Old rotors, in spec, legal jargon, Blah, Blah, Blah) would release a shop from liability if there were an accident that could be some how traced back to stopping the car So if your car is pure shop repaired, pads & rotors would be expected DIY - its your call and your responsibility to keep it safe |
New or turned rotors is just standard procedure and good business for a Porsche shop. It makes certain that the cars brakes are at their best and feel smooth, fresh, and new which eliminates callbacks from: "You guys said you did my brakes but I still hear a grinding noise. I'm not leaving until this car is right and I'm not paying for a job half done." We Porsche drivers can sometimes be a PITA ;) As a DIYer, I never resurface a rotor measured within spec that I deem serviceable. If it is heavily grooved, I go new. Rotors are cheap and expendable with front OEM Zimmermans at about $100. Hospital stays are expensive so choose wisely. |
Regardless, y'all make a good point about liability with mechanics. It makes sense, and I suppose complaining about it doesn't change that fact, so...DIY for me or wait 'til I can afford the full treatment. :) |
Kk2000s, if you cant afford to do brakes on a boxster, you cant afford to drive. There is really no excuse not to be able to afford maintenance items like brakes when you have ebay and amazon at your disposal. You can do one of two things. A. Buy the parts online and bring it to ANY reputable shop B. Buy the parts onine, and do it yourself. |
New parts worship
As for time? Yes, it takes less time to change rotors, But more brake jobs in a day? I get maybe 2-3 brake jobs a week. The rest is usually more complicated stuff |
Well good for you, I agree with that theory. Kinda rare here in SoCA. With all the traffic brakes are big business here, I've seen 1 mechanic do 5 cars in 8 hrs. I don't know of any dealerships that still machine rotors. :(
| All times are GMT -8. The time now is 05:51 AM. |
