Old 05-17-2013, 02:33 PM   #1
Used Oil Analysis
Hi folks
Completed my first oil change as part of IMS Guardian install (some pics on my Rennlist thread). Was due in July for 12 month service so its been 10 months or 6000 kms since last change. Engine run exclusively on Mobil 1 from new and has done 109,000kms. Current grade is 5w 50. UOA is:
Cu 23ppm
Zn 817
P 709
Fe 8
Al 2
Cr 1
PQ 0
Main concern is Cu but Zn and P are lower than nominal (1100/1000). Have refilled with Fuchs Titan Supersyn 5w 40 and will check again in 6 months. Interested in your thoughts/ comparisons.
2004 Boxster S
Suzuki Grand Vitara 2.5LV6 / Nissan Elgrand 3.3L V6
Ducati 900SSie / Ducati Pantah 600SL (race bike)
PhilNZ is offline   Reply With Quote
Old 05-18-2013, 06:07 AM   #2
At my fall oil change, with Mobil 5W50 my copper was at 7 and my Zinc and Phos. were at 1,669 and 1,196 respectively. Our Alum and iron number are similar. About 52,000 miles on the motor and 6,700 miles on that oil.
Old 05-18-2013, 01:37 PM   #3
Thanks, good data. Looks like I'm being short changed on Zn. Your Zn level is double mine and were using the same brand/grade of oil. Mobil 1 gets the big thumbs down from me. I dont think that variability is acceptable at $20/L. Pleased I changed brand but need more data to know if its the right choice.
2004 Boxster S
Old 05-20-2013, 09:16 AM   #4
Phil,
Do you know the particle size range that the lab's equipment can see? Many spectrometers can only see up to about 5 to 10 microns, and usually report in the up to 1-2 micron range. Hardened steel will flake off and cause ~15 micron (and larger) sized particles -- these would never be detected and reported (depending on the equipment).
Regards,
paul...
paulv is offline   Reply With Quote
Old 05-20-2013, 11:25 AM   #5
Originally Posted by paulv View Post
Phil,
Regards,
paul...
Thanks, interesting comment. I'll give the lab a call and find out. The filter was clean and there was no particles visible in the sump or the oil pan so I'm hoping shes clean
2004 Boxster S
Old 05-18-2013, 08:45 AM   #6
Copper is high, but not stratospheric. I would just do another short interval oil change and check the copper.
Phosphorus and zinc are low, but those are anti wear additives which vary from oil brand to,oil brand.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
