05-06-2013, 04:18 AM
#1
Underdrive pulley recommendation
I'm wanting to get an underdrive pulley for my 2.5. I've been looking at a few but was wondering if anyone could make my mind up for me. I've looked at the precession chassis works pulley and Chetah online pulley. I've seen another pulley that looked a bit weak and for sure found pics of it broken. If there's any others people could recommend it would be most appreciated.
05-06-2013, 12:40 PM
#2
what type broke? I've done little research but RSS looked lightest to me. I'm probably going to try using 987 idler pulleys as well as I've read here that there aluminum.
05-06-2013, 02:59 PM
#3
RSS seems to be the popular pic here.
Beware of BBI pulleys. They have a tendency to do this:
98 Arena Red 986
05-06-2013, 04:47 PM
#4
I've decided to go with tarett engineering. Looks strong and the price seems good at $175.
05-06-2013, 07:04 PM
#5
Yikes ! I have the BBI LWUP !
05-06-2013, 04:51 PM
#6
I would go with either Tarett or RSS, you can't go wrong with either one
2001 Boxster S
RUF front bumper, Techart side skirts, Gemballa rear bumper, PSS9s, Cargraphic 18" racing wheels, RUF exhaust, GT3 seats
05-06-2013, 06:08 PM
#7
I installed the RSS UDP. Worked great. You can also buy the smaller/correct size serpentine belt at the same time.
RSS Under Drive Pulley for Porsche Boxster, Cayman, Carrera, Targa
05-07-2013, 07:51 AM
#8
Homeboy981
Originally Posted by thstone
Had to go with RSS because of it was too important to fail.
05-08-2013, 11:17 PM
#9
stupid question maybe, but how are UD pulleys not universal? I can see cam diameter varying in sizes, but there should be a lot of UDPs that fit the box, that does not make you pay the premium...
Stop lights timed for 30 MPH, are also timed for 60 and 90 MPH!
05-09-2013, 05:50 AM
#10
There are more variables than it may seem, besides diameter; bolt size, number of bolts, bolt circle diameter, pulley offset, center hole size, keyway/pin size & location, V-groove width/depth (this may be fairly standard?), etc.
05-09-2013, 06:01 AM
#11
Good monring gentlemen
Being that we are all having a nice friendly chat about UDP's - how easy is it to change/install.
Not looking for a full blow by blow account but can a fairly unskilled person do it or does it require a higher level of knowledge and does half of the interior need to be removed or can access be gained with seats and console in place.
Don't care......was made to care! (my Mum)
05-06-2013, 06:48 PM
#12
1998 Boxster
I purchased the tarret. It came with a new bolt which is recommended regardless of which brand you choose. Also, I think the Tarret is a 4" pulley, whereas some of the others are 5". I am not sure what this means in terms of performance. Would be good to know .
05-07-2013, 04:47 AM
#13
All the ones I saw when I did mine were 3". Didn't matter the brand, price, or what milling of the body looked like... They all had a 3" diameter.
05-07-2013, 04:11 AM
#14
I have just fitted this one, bbi.
05-09-2013, 05:07 AM
#15
To those of you that have installed a UDP... What real difference have you seen.... and if one of you that trolls looking for an opportunity to scold me for not using the search function - please don't... If you have no other response - no need to respond.
I was just reading this an was interested.
Pup
Sorry guys, but sometimes that Use Search Function spanking , gets to me.
1999 Boxster Base Ocean Blue Metallic 5 speed with hardtop
2015 Porsche Macan Turbo
2021 Mini Cooper S Convertible, Black Leather, 5 speed The Misses car
05-09-2013, 05:27 AM
#16
Pup.
They were first developed with the purpose/idea to simply slow down the accessories (power steering pump, alternator, AC compressor) on a car that spends a lot of time running high revs. 986/987 PS pumps are known to overheat and leak under heavy track use.
A side benefit is that the underdrive pulley reduces parasitic drag from these components and you can measure an increase in hp and torque at all rpms between 5-10 rwhp depending on the model.
Don't have one myself (yet) but only heard good things!
05-09-2013, 09:38 AM
#17
Thanks Essex for the info....
Pup
10-11-2013, 10:04 AM
#18
Anybody install Pedro's pulley? Most seem to recommend RSS. Any pluses or minuses for either one?
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
10-16-2013, 09:55 AM
#19
My Pedro UDP came in yesterday. As soon as get a minute to install this puppy I'll let everybody know what's up.
'99 Boxster Artic Silver/Red
'14 Subaru Outback
'06 EG Classic
'05 Sportster
10-23-2013, 07:57 AM
#20
Install was done this weekend. I was going to it on Thursday, but I only had a 24mm deep socket, and you need a regular. Took me a while to get the pulley seated properly and tightened up so it didn't wobble. I cut the boss off with a sawzall, it only took about 15 minutes, no problem. Once I did this I put it all back together and went for a spin. You can definitely tell it has more grunt than it did before. I does accelerate better in all gears, and gets to 100mph in a more timely fashion. Not a bad mod at all!
'14 Subaru Outback
'06 EG Classic
'05 Sportster
