Old 04-16-2013, 07:33 AM   #1
Mud Flaps
I need some help, can someone tell me how to install a mud flap, the one that goes in front of the rear wheel.
artneop is offline   Reply With Quote
Old 04-16-2013, 08:29 AM   #2
mountainman's Avatar
No big problem. You need to either jack it up or put it on a lift. I think there are 3 torks screws in the bottom and there is one behind the inner wheel well plastic liner. It is easier to access with the rear tire removed. Takes only about 20 minutes to do. When you get the new one it will be easy to find where the screws are.
Old 04-16-2013, 08:30 AM   #3
No big problem. You need to either jack it up or put it on a lift. I think there are 3 torks screws in the bottom and there is one behind the inner wheel well plastic liner. It is easier to access with the rear tire removed. Takes only about 20 minutes to do. When you get the new one it will be easy to find where the screws are. If you were closer I'd change it for you on my lift.
Old 04-16-2013, 11:56 AM   #4
Coffinhunter's Avatar
Just say no!!!!!!!
First monster wings, then hub caps, now this??????
Sorry couldn't help myself
Old 04-16-2013, 12:09 PM   #5
Homeboy981
Homeboy981's Avatar
First, you need to remove the inner wheel well plastic (it takes a 10mm socket) and there are 2 plastic bolts. Remove the wheel well piece to gain access to the third, or top screw of the Stone Guard/Mud Flap/Cone Magnet. The other 2 screws are easily found on the bottom of the vehicle where @mountainman said.
Old 04-17-2013, 07:22 AM   #6
Smile Mud Flaps Instalation
Thank you guys! you are awesome!!
Old 04-17-2013, 11:00 AM   #7
srad34's Avatar
Why would you put mudflaps on a Boxster? Is it for going off-road?
It will all end in tears I tell you.......
srad34 is offline   Reply With Quote
