-   -   Front hood latch question?..won't pop up... (http://986forum.com/forums/performance-technical-chat/43328-front-hood-latch-question-wont-pop-up.html)
Timco 02-26-2013 07:24 PM
What makes the hood pop up when you hit the release? Mine releases but barely pops up enough to get my fingers in there.
Thank you, thank you, so very, very much!!
BrokenLinkage 02-26-2013 08:34 PM
me too
Mine just started doing the same, haven't had time to investigate yet.:confused:
Meir 02-27-2013 02:11 PM
just spry it with a lubricant and open close several times.
WD40 did the job for me.
1olddude 02-27-2013 03:57 PM
+1 on lube. Works great after that.
Timco 02-28-2013 07:52 PM
This is the first problem I was able to fix for under $100!!!!!
Thanks!!
Meir 02-28-2013 08:11 PM
Thanks!!
What do you mean?
Didn't you use the WD-40 Porsche audition?
They go for $100.99 a can :D
