Just switched to Red Line oil
5w40, and the start up clatter is much better. It hasn't gone away completely, but I'd say its 80% better.
I tried many types of oil, from M1 0w40, M1 15-50, Castrol 5w40, valvoline 20-50 and there was no difference in start up clatter. I think I'll stick with Redline. Its expensive, but when you look at it the difference in cost is about the cost of a tank of gas. |
I switched from Mobil to Redline last fall, and clatter from timing chain seems to be reduced by about half on cold starts and gone completely on warm starts. Cost was about $130 buck shipped for 11qts.
Is there any negative effect to timing chain clatter?
Start up clatter can be a cuople of things, chain tensioners may be worn, the hydraulic lifters may be worn, the chain guides may be worn. Its pretty common in these motors. I just live with it.
Negative effect? Something is not quite perfect, but after you replace the tensioners, finding the problem can get pretty expensive. |
Used Red Line 5W40 for about 3 years. Great oil.
I was away for a week on business travel (I was only allowed a compact rental and it was a Hyundai) and when I got home, I fired up the Box a couple of days later -- hardly any startup noise. Thx Redline, Thx ester basestock, Thx ester for being a polar molecule and adhering to all the metal parts!!
This is why I went to Redline. Regards, paul... |
Red Line Oil
Funny, but I can't remember anyone here mentioning Amsoil .I know a lot of folks who swear by it!:)
The 4-ball test, used for testing boundary regime lubrication (metal to metal contact because the oil film is gone) seems to point to the additive package and not the basestock oils, in my non-lube engineer/non-tribologist mind! I'm not moving off of RedLine for the reasons I posted above. Regards, paul... |
Just curious. What is Amsoil's marketing approach?
It's most likely a good oil since many people use it, but there are also many other good oils out there. It depends on what "good" means to people. Regards, paul... |
| All times are GMT -8. The time now is 12:58 AM. |
