Old 12-15-2012, 05:24 PM   #1
Chuck W.'s Avatar
Flat Spot During Hard Acceleration & Now Engine Code 1126
I believe I may know the problem and just some confirmation. I have a 2001 Boxster S six speed with 21,400 miles on it. Original owner, no engine mods and stock air filter.
During hard acceleration (WOT) I hit a flat spot momentarily while passing about 3300 RPMs. Nothing major, but you can feel it.
Several months ago on a hot day the check engine light came on. I got home and checked it and it was 1126. I did my due diligence and came up with several issues that could have caused it. I put some lube on the O-ring of the oil filler cap, cleared the code and have put about 500 miles on the car without issue. Until today.
Today the check engine light came on and after checking the code reader I found it was the same 1126 code. Based on this code and the flat spot at 3300 RPMs I am thinking that it is the MAF based on my reading of this and other Porsche forums.
Thoughts? TIA
1995 Porsche C4 Cab
Old 12-15-2012, 05:40 PM   #2
My 1126 and 1128 code went away after a thorough cleaning of the MAF using mass air flow sensor cleaner.
brian325is is offline   Reply With Quote
Old 12-15-2012, 05:50 PM   #3
Chuck W.'s Avatar
How long / many miles ago?
1995 Porsche C4 Cab
Old 12-15-2012, 06:52 PM   #4
As Brian said, clean the MAF. If you have a Durametric, look at all the MAF parameters to see if theyy are out of spec. Another thing to check is to see if you have a vacuum leak.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 12-16-2012, 07:01 AM   #5
thom4782's Avatar
My troubleshooting guide suggests checking these items for proper operation in the following order:
  1. MAF
  2. Exhaust leak
  3. Intake leak
  4. Fuel pressure
  5. Fuel volume
  6. Injectors
Old 12-16-2012, 08:52 AM   #6
It has been a year since my codes went away. I also had purchased a new MAF online ( not bosch ) and the car ran terrible with it in. Cleaned and put the old one back in and it has been code free ever since.
Old 06-24-2014, 08:04 AM   #7
Chuck W.'s Avatar
I can't believe I didn't post a follow up to this thread. It was in fact the MAF that caused the codes. I tried cleaning it without luck. I replaced it with an aftermarket Bosch unit I purchased from RockAuto. All good ever since the replacement.
1995 Porsche C4 Cab
Old 06-24-2014, 11:55 PM   #8
Which part # did u get from RockAuto? I am getting codes due to the MAF but I just shipped my '01 S so I can't check the part. I want a new one waiting for when I pick up my car.
Thanks.
mump is offline   Reply With Quote
Old 06-25-2014, 08:43 PM   #9
Chuck W.'s Avatar
BOSCH 0280218055; More Information for BOSCH 0280218055
This is the MAF for a Boxster with traction control (PSM).
1995 Porsche C4 Cab
Old 06-25-2014, 09:24 PM   #10
Danke, that is what I need.
Old 06-26-2014, 01:03 AM   #11
sweet, just ordered.... and only $164 shipped. everywhere I was reading they were saying $200+
Old 06-26-2014, 07:30 AM   #12
Chuck W.'s Avatar
Good deal. They have come down in price since I bought mine in February of last year. Then it was $181 shipped.
1995 Porsche C4 Cab
