11-17-2012, 07:11 AM
Homeboy981
Are Headers Do-Able For Street This Way?
I'm trying to get more performance out of intake and exhaust systems. To that end I have been shopping Exhaust Headers for some time. However, IF you want to pass inspection, you cannot remove the PRIMARY CATS. I have looked into re-programming, mini-cats (about an inch or two long), spark plug de-foulers (moving out of exhaust stream)….ALL do NOT seem possible.
Then I hit on this….buy Performance Headers and have a muffler shop weld in the old cats from previous system. Is there any reason that should not work? The tube diameters are similar, they can weld in the bung holes for O2 sensors…and we're good, right?
If not, please explain….gently!
11-17-2012, 07:20 AM
The boxster, as you probably know, was 2 sets of cats. Technically you could resort to a single header design and reroute the O2 sensors to the secondary cats. Keep in mind, the secondary cats are just as restrictive (and maybe more if they' share the same part as a 996) as the primary cats. With that said, there's really nothing to be gained as far as performance is concerned. As I've said numerous times in the past, there's no short cut or inexpensive way to improve upon the oem exhaust system .
11-17-2012, 07:55 AM
Homeboy981
Hey @JD,
This IS DEFINITELY not a "short cut", more like several difficult cuts, followed by welds and such.
I already have Cat Deletes, so my secondary cats are gone!
But having a better "outflow" design, in other words, longer tubes for EACH of the cylinders helps, doesn't it?
Don't longer tubes ALWAYS solve most problems, particularly from the exhaust?  Kidding about that but VERY SERIOUS about trying this. If it is worthy. Know anyone who has done it?
Mark
11-17-2012, 08:51 AM
if you want longer tubes for each cylinder, they why not put the cats on your mid-pipes instead of your headers? if you buy that logic, then you can re-install your old mid-pipes (they might be of a restictive diameter, however) add cats to your current aftermarket midpipes, or buy a set of midpipes with sportcats from one of many vendors. either way, you would probably need to add a bung after the cat and extend your sensors.
another option is to wait for che. from all reports a 987/cayman exhaust will fit on a 986. che will be selling catless headers for the 987 shortly (for some odd reason there are currently no cheap chinese headers for the 987 like on the 986). then you can just find an oem take-off for the mid-pipes and muffler - better sound, bigger diameter, cats located well downstream at the muffler.
Originally Posted by Homeboy981
Hey @JD,
Mark
Yes, on the longer, equal length primaries on the headers. However, it has been my experience that going completely catless reduces low end to mid range torque. There needs to be some back pressure.
11-17-2012, 10:17 AM
I feel as though you're focusing on the wrong places for horsepower. If you haven't already, you should look into the intake and ecu remapping that Pedro's Garage offers. I believe they have labeled this as the "TechnoKit". For less than $1500, they claim almost 40hp.
You'll be looking at spending close to that on the exhaust upgrade you are describing. And yes, you would be able to pass a smog inspection, but I feel you're not really thinking about this in a proper sense. As Mr. Danger has states numerous times, there is no cheap exhaust upgrade. Although I cannot see pouring as much money into my exhaust system, as he has into his, i must say his is done right. And as far as tastefully modified boxsters goes, his is the bench mark.
To be completely frank, welding your old cats onto new headers, is going to not only look tacky, but will drop your performance gain of those headers significantly. If they claim 15hp, that is of course with the cat delete. Putting them back on could significantly reduce that performance gain.
In my mind, as johnny has already stated, there is no cheap way, or short cut to a proper exhaust modification on 986 exhaust systems. And although it may be hard to face, what you are describing is a short-cut. Although not cheap or fast, you are only attempting it to avoid the extremely expensive and long process of doing it "right".
Hope this is helpful,
Brad
11-17-2012, 10:41 AM
Homeboy981
Hi @Brad,
Not what I wanted to hear, but maybe I needed to hear it.
You may be right. However, I am ONLY looking at $150 for headers and can easily take the the pieces down to my local muffler shop and have him do the "Cat swap" for less than $100. I already have cat deletes and have a Top Speed Pro-1 Cat Back Exhaust in my sites. I DO understand the exhaust WILL NOT flow as well as FULL Headers and likely there will be some lost HP, as a result of keeping the cats in there, I cannot afford to do without them totally…yet.
The reason all this is becoming necessary is because I have the intake portion just about dialed in. While the Pedro mod may be better for a stock intake, there is nothing stock - or EVEN AVAILABLE, that is LIKE my intake. I have my Stage 2 Intake completed (HUGE Air Filter, 4" silicone tubing to 3.25" with the MAF housing RIGHT BY the Throttle Body). It is flowing a TON of air! ECU mapping is next.
It may seem like a 'short cut' or "tacky" to some but compared to the cost of hi-performance cats, more than a grand more….this is much MORE do-able ON A BUDGET.
I DO however value your opinion and will take it under advisement. I may be saying, "Curses I really wanted to get Headers" but, it may be an exhaustive pipe dream, that is the reason I asked the ????.
I was told the Air Intake system would LOSE power too….but it doesn't and I am a happy camper for only spending a couple hundred and some time in R & D (therapy for me).
So, if anyone has a way it CAN BE DONE, or you have been able to make the Headers work, without breaking a fragile piggy bank, given the set up I have…please enlighten me. Or, maybe it will be an 'exhaust pipe dream'. Thanks!
