Water Pump Flat Rate?
Does anyone know how many hours the factory flat rate manual calls for replacing the water pump on a '03 S, including the drive belt? I suspect this info is already on here some place, but my search has been unsuccessful. Thanks.
The Mitchell system states that a WP replacement is 2.8hrs (warranty work is 2.0hrs) for my 2007, so I would imagine that it's close to that time for your MY. Serpentine belt is 0.9 hrs.
Regards, paul... |
The system I use for the shop I work for, Shopkey5.com, says 2.8hrs (2.0hrs for warranty); Just as Paulv says his Mitchell system says.
The drive belt has to come off, so replacing the belt would be included in that labor. |
| All times are GMT -8. The time now is 08:10 AM. |
