Old 08-15-2012, 01:45 PM   #1
front passenger seat removal
Hello: I just purchased a 2005 Boxster and the previous owner left a large CD case holder under the passenger seat and from moving the seat forward and back the drive motor came disconnected from the left hand drive rail mechanism. I have been able to remove the back two torx screws from the back rail. But unable to find the two front torx screws for the front rails, I have removed the plastic cover over the front rails. The seat is stuck in the forward position. Is access to the front two torx screws from underneath the car, under the plastic cover? Any assistance will be much appreciated.
Thank you;
Gerd
Gerd is offline   Reply With Quote
Old 08-15-2012, 03:17 PM   #2
They are at the front end of the rail facing forward at an angle. You will need to move the seat back to access them. You should be able to move the seat even though the back ones are removed.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 08-15-2012, 05:01 PM   #3
golonaus's Avatar
It is up front under plastic cover.
Good luck
